Battery reversed, bike dead
Old 06-16-2019, 08:19 PM
RANGER73's Avatar
RANGER73
RANGER73 is online now
Received 5,924 Likes on 3,022 Posts
With the battery connections reversed any LEDs wouldn't work but the only damage would be the starter would attempt to turn backwards, this is not good.
Depending on if it cranked much or at all you would also have shorted the stator and regulator.
  #42
Old 06-16-2019, 08:41 PM
Rugger80's Avatar
Rugger80
Rugger80 is offline
The problem was the wire running from the positive post on the starter to the main circuit breaker, the first wire I checked. Replaced this wire and everything worked. I believe the solenoid clicking is due to the battery.
  #43
Old 06-16-2019, 08:54 PM
RDHIGH's Avatar
RDHIGH
RDHIGH is offline
Im glad you figured it out. New battery should do the trick. Happy trails!
Rugger80 (06-16-2019)
  #44
Old 06-17-2019, 08:14 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,499 Likes on 4,612 Posts
Thanks for the follow up. The wire that was fried is the only part of the circuit that is not protected by a fuse or breaker.
  #45
Old 06-17-2019, 08:37 AM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,541 Likes on 3,793 Posts
Since that wire is driving the four small circuits protected by 15 or less fuses, it's my thought the it probably had corrosion at the crimp. Could have been the originial start problem since with it bad, the soliniod of the starter would not get full voltage. When the battery was incorrect, conflicting DC current took out the high resistance. If the cable was OK, it should have taken out the 4 small fuses.
Just an opinion...
  #46
Old 06-17-2019, 09:21 AM
RANGER73's Avatar
RANGER73
Try jump starting it without the existing battery, you'll see if it's the battery or not.
  #47
Old 06-17-2019, 09:24 AM
RANGER73's Avatar
RANGER73
Then check the incoming voltage to see if you damaged the stator or regulator
  #48
Old 06-17-2019, 08:07 PM
Rugger80's Avatar
Rugger80
Rugger80 is offline
Good idea, will do.
Weeboy1
Engine Mechanical Topics
04-23-2017 05:37 AM
Mchlumsky
12-27-2016 11:29 AM
KW HD
06-15-2015 04:30 PM
Nautilus
EVO
16
11-10-2010 07:28 AM
Dustmaker
09-22-2008 10:13 PM
Quick Reply: Battery reversed, bike dead
