primary chain adjustment without moving the wheel
No. Metrics have caps to remove. Harley had a different idea.
Always wondered if they have always been that way or somewhere along the line, the bean counter saved a few dollars
Depends on how you treat it, after that first check, I doubt it ever changes. My clutch and primary settings are the same after 50,000 miles . Now if you beat it, no telling.
You are close. Think you also have some letters. See my FXSTDI. Think you have something like ...XL883NIRON (LE)
Not sure. Gets real hard to remember and different areas and countries
By turning the engine and checking the tension on the chain you are looking for the tightest spot. Clearly the MoCo is telling you there is runout in both shafts plus some out of round in the sprockets the chain runs on.
You can guess and set the tension to somewhere between 3/8 and 1/2 and hope for the best or you can do it as stated.
Sprocket are some of it but chains wear uneven if you flog them.
