06 sporty rear lighting
While out for a ride on my custom 06 883xl,I lost all power and my bike died,a passerby helped with a multimeter,I traced the problem to a "module,circuit board?" The rear lights all run thru it and it had grounded due to poor wire routing after the custom work,I have tried to find this " device" in my workshop manual,and parts catalog,but no luck,it's not the tssm but a small rectangular plug with foam backing and a circuit board,the turn signals and brake light are wired thru this as I suspect? What's the name or designation of this device? Anybody?
Last edited by Steworeed; 05-09-2021 at 06:31 AM. Reason: Need name of mentioned device
The info you need is at Ronnie's parts finder...fortunately that "CIRCUIT BOARD/COVER ASSEMBLY" should be available and it is not expensive...
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
Rear lighting
The PO used various parts on another project,this module is a junction do the rear lighting but has a circuit board,I don't know how to get a pic.on here but will try to find out and thanks for the response guys I have ran a brake light from external switch could not wire the pressure switch for the rear brake,either bad or wired thru the tssm I've been researching the wiring and I beleive that the module is a junction for the same,I will try again to run it down in my service manual before I bother you guys with incomplete info,I'm stumped
06 rear lighting
I've read that the tssm would stop the turn signals and brake lights,the turn signals I unhooked in hope of the brake lights working( no luck) but the turn switches started activating the dash accessory lights to the blinkers when I unhooked them so there is a problem there,aftermarket,I will seek factory turn lights and try to see if this helps altho the module in question is damaged
Wiring diagram - 99949-06_en - 2006 Wiring Diagrams | Harley-Davidson SIP
14StreetG_cruiser
Electrical/Lighting/Alarm
03-27-2017 11:06 AM
