Clutch issue ???
Clutch issue ???
2002 883 hugger , ok picked a lowmilage 2002 883 hugger , had a issue when bought it with clutch , so i had a new clutch put in it , rode it for a maybe 200 miles same issue has returned , so its like the cable is binding up ,like the releasing assembly is in a bind and not working , so im wondering if anybody else has had this issue and what it could poss. Be , was planning on replacing the entire release assembly and the clutch cable , but just wanted to get imput on this , i have never had this issue before.
Did you replace your release bearing? There is an upgraded, angular contact bearing, that is a common replacement. I forget the number, 2500B or something like that. Sounds like that could be an issue, but lube the cable and check the ball and ramp assembly too. Those are basically the three parts involved.
John
John
The following 3 users liked this post by John Harper:
John Harper (04-29-2024)
John
John
John
John
96hugger (04-30-2024)
