Thanks, I can just remove it or do I need a spacer to replace it? Im changing the rear tire this week might as well take that out as well. By the way its only on one side wouldnt it need both sides to lower the bike?
Remove it. I'm not sure those shocks bolts are original, so when you reattach the shock on each side, be sure the bolt doesn't sitck too far out on the inside or rub on anything.
Or, look for a spacer at the upper shock mount and remove it as well as the lowering block. The shock needs to be square to it's mounts. Check that lower bolt for proper length as well.
John
