Front wheel noise
RE: Front wheel noise
Sounds normal to me...Just make sure it isn't a metal on metal noise, then you know it;s time to change the pads. Supposedly if you get the Lyndall Racing Brake pads http://www.lyndallracingbrakes.com/home.htm
it should get rid of the nosie. I hear the pads are dustless as well so your wheels will stay cleaner too...
If it stops when you apply the brakes, it's most likely the brakes. However, if you are just coasting along and it makes a repetative noise in sync with the wheel, it may be bad bearing(s). So brakes or bearings.
EDIT: If it's the brakes, and it's just a "rubbing" noise, not a scraping or anything, it's probably fine. A bad bearing poses a huge safety hazard, though, and needs to be replaced.
