front wheel noise
Old Aug 9, 2015 | 11:27 AM
gilbert.dan's Avatar
gilbert.dan
Stage II
Default front wheel noise
I have a 2011 SG. I recently changed front discs and pads. I had no problem pushing back the pistons so I know they are not seized. However, I noticed the other day that at low speed (around 50km) I can hear a noise from the front as if the brake pads were dragging on the disc. Even if I apply pressure on the brakes (front and back) I still hear the noise which leads me to doubt it's a brake problem. Any ideas on what could be the cause?
Old Aug 9, 2015 | 02:04 PM
dawg's Avatar
dawg
Wheel bearing? Tire?
Old Aug 9, 2015 | 02:07 PM
mainboom150's Avatar
mainboom150
its the sound of the pads breaking into the rotor
Old Aug 9, 2015 | 05:28 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The description could be the sharp edges of the new pads catching the holes in the rotors. I first noticed this after first pad change , after that I just rounded/beveled the edge down and the little noise wasn't there.
Old Aug 9, 2015 | 08:18 PM
gilbert.dan
Stage II
Thanks for the tip....hopefully it'll work for me too.
Old Aug 10, 2015 | 09:41 AM
casique's Avatar
casique
It will go away as it sits finally on the rotors. Mine did the same.
Old Aug 10, 2015 | 08:26 PM
mikeo33y's Avatar
mikeo33y
did you seat your brakes. many people dont know this and even the harley manual says to break them in slowly but that is the exact opposite on how to break in brakes. you have to slam on the brakes hard 12 or 13 time to seat the pads to the discs. this is proper procedure and your brakes will work much better after this is done. do not drag your brakes to wear them in. very very bad.
Deuuuce
Jul 20, 2016 06:24 PM
EGLSFAN
Jun 5, 2011 01:05 PM
challutz
Wheels/Tires
Aug 15, 2010 08:51 PM
colmeg
Oct 23, 2008 12:05 PM
ron1019
Oct 24, 2007 06:56 AM
