Front wheel noise common?
Old Jul 20, 2016 | 02:08 PM
Deuuuce's Avatar
Deuuuce
Default Front wheel noise common?
When coasting in neutral, engine off, I can hear a faint "shhhhhhh" noise that isn't road noise and sounds more like the brake pads barely brushing the rotors.
Is some noise normal or is it something that needs correcting?
Background: Finally replaced the stock front wheel on my 2011 Street Glide 103/ABS with a take-off Agitator black ice wheel. Looks amazing (imho).
Old Jul 20, 2016 | 02:44 PM
danzio's Avatar
danzio
It is quite common and not abnormal. My brand new '04 Dyna did it quite a bit but my '07 Ultra does not. It is as you suggest, the brake pads slightly rubbing.
If the noise becomes excessive and starts to sound more like a grinding/squealing sound then you may want to put it up on a jack and rotate the wheel to make sure it's not your bearings. That would be a problem to address immediately.
gpeake13j's Avatar
gpeake13j
normal. rotor moving through the pads
Old Jul 20, 2016 | 02:56 PM
RKZen's Avatar
RKZen
Kind of common when you change out the wheels. Those rotors might be a smidge closer on one side of the break pads.
Old Jul 20, 2016 | 06:24 PM
Deuuuce's Avatar
Deuuuce
Thanks guys! I feel much better about it!
Saturday the rear wheel goes on....hopefully just as smoothly!
gilbert.dan
Aug 10, 2015 08:26 PM
EGLSFAN
Jun 5, 2011 01:05 PM
challutz
Wheels/Tires
Aug 15, 2010 08:51 PM
douglas07UC
Wheels/Tires
Jan 2, 2010 07:29 PM
colmeg
Oct 23, 2008 12:05 PM
