No other mods needed just for slip on mufflers. I've done several of these installs. I usually find it easier to go ahead and take the entire exhaust off the bike. This allows for getting a better grip to get the mufflers to "slip off" I use plenty of WD-40, and application of a rubber mallet around the joint to help get the mufflers off.
Some are fairly easy, and some can be a real pain to get the muffler off. Mine was a ROYAL pain, but I've done others that weren't too difficult. Either way, it's a simple straight forward install. Just sometimes difficult to get the original mufflers to let go.
The first time I tried to get my stock mufflers off I used wd-40 it took me 3 hours wrenching and twisting and fighting with the pipes. The second time, I used Liquid wrench. I liberally used it at the joint where the two pipes connect waited 30 minutes and the exhaust slipped right off. . .
- G
- G
You proved to yourself something that has been said 10 thousand times on this forum. WD40 is NOT a penetrating oil,and NOT a lubricant. Liquid Wrench,PB Blaster, and 100 other 'penetrating' oils would be a better choice than WD40
Apart from the baffles and the heat shields , my V&H Straightshots are little more than tubes . I can't really see where the money goes .
Mostly from your pocket to theirs.
Ya ever watch an episode of Shark Tank? Some of their primary questions are, how much to make it, and what does it sell for. I have heard them over and over complain when an item costs, say $5 to make and sells for $20. They want $5 to make it and sells for $40-45. I know they need to make a profit, but it really lets me see why prices are as high as they are, especially when so many are sending their stuff overseas for production.
