Baffles SE II Slip-on
I've tried to remove the baffles \\;from my SE II slip-ons on my '05 1200 Custom to mess with them a little. \\; Took out the bolts on the bottom \\;&\\; side thinking they would just slide out. \\; No way. \\; Any other bolts, or secrets? \\; Help please.
RE: Baffles SE II Slip-on
Thanks for the response schumacher. \\; I thought of the pliers/tug routine, but there's not anything to grab &\\; ******. \\; No flanges, tabs, ears, etc. \\; Just metal against metal. \\; Short of taking the pipes off &\\; tapping them with something from the entry side, I can't figure out what to do.
Try the attached methods. \\;\\\\\\;\\\\\\\\\\\\\\; In my case there was a little lip iside the baffles that I could get on. \\;\\\\\\;\\\\\\\\\\\\\\; I think I have a picture of the baffle in one of these posts.
This method worked in about two light taps of the hammer for me.
https://www.hdforums.com/showProfile.asp?memid=26821
Edit:
Ok, that didn't work. \\;\\\\\\; Do a search on my username, and you will get a list of posts. \\;\\\\\\; A couple of them address my method of extracting the baffles. \\;\\\\\\; A lot easier than pulling the pipes, and anything else I tried.
If I could figure out how to give you a direct link, I would.
Edit 2:
Try this??
https://www.hdforums.com/m_3550132/tm.htm#
That workedat least gets you to the thread. \\; My post is 5 or 6 down. \\; \\; Might be some other ideas there, too.
Edit:
Edit 2:
Try this??
pab
Exhaust System Topics
07-20-2008 03:14 PM
