rear tire question
rear tire question
I need a new rear tire, 9200 miles on the stock Dunlop and there ain't much left of it. The front is still in good shape. Can I run a Metzler tire on the back and keep the stock Dunlop on the front?? Someone said mixing tire brands on a bike isn't good but I have no idea......
From searching on the forum it sounds like the Metzlers get good mileage and performance and are cheaper than stockers?? Any thoughts?
I really think that this more or less pertains to the Sport Bike crowd were you could be at high lean angles and really depending on the tire materials a little more. The high performance tires are built to work together. It is not to say that I never had two different tires on my 600RR though, I was just more careful. As long as your not out there scrapping parts of your bike all the time you should be fine.
Thanks for the feedback. From what I understand, the Metz 160 series is the same dimensions as the the Dunlop 150 series?? On this website, the 150 metz is $124.99 and the 160 is $158.99. Both are cheaper than a harley dunlop through dealer. Which size should I order?
http://www.motorcycle-superstore.com...Rear-Tire.aspx
