Life Span of a Sportster
Old 12-10-2008, 08:44 AM
Chips's Avatar
Chips
Chips is offline
Default Life Span of a Sportster
I have 65 000 kms on my '05 Sportster.
Assuming I do regular..good maintence, how many miles / kms can I expect to get on this bike? ...before the motor just 'wears out'?
I love this bike and was just wondering what the 'life span' is on a Sportster?
Old 12-10-2008, 09:06 AM
Sick1200's Avatar
Sick1200
Sick1200 is offline
There's a guy here (I forget his name) that has put over 100,000 miles on his, if that answers your question. It mainly comes down to how you ride it, and what you call good maintenance. If you keep the motor itself stock (don't bore it out, or put bad *** cams, etc.) and you don't hot rod the motor around town (where's the fun in that!), it will last a long time.
Old 12-10-2008, 09:24 AM
lolife's Avatar
lolife
lolife is offline
I was hoping to get about 7k out of this one............ . . . . .. . . . . .
Attached Thumbnails Life Span of a Sportster-dsc00612.jpg   Life Span of a Sportster-dsc00601.jpg
Old 12-10-2008, 09:27 AM
Chips's Avatar
Chips
Chips is offline
100 000 miles is good to hear. I wonder if that's an exception or an expectation.
By "good maintenance" ....
I tell my indy; "Make it 'like new' ...fluids..cables..brakes..tires..what ever it needs."
I assume that fresh oil is the best advice for long life span?
Old 12-10-2008, 09:42 AM
FastHoss's Avatar
FastHoss
FastHoss is offline
Just ride the damn thing hard,you may die before the engine does,don't worry about tomorrow
Old 12-10-2008, 09:50 AM
traveler's Avatar
traveler
traveler is offline
I agree....if your bike isn't smoking and still has compression, then it's fine. 100,000 MILES seems very do-able to me. Just keep rebuilding it, but at some point the lifter blocks will be shot, and since they're not replaceable that's when the case has finally had it....but that at like 250,000 MILES++
~Joe
Old 12-10-2008, 09:53 AM
Chips's Avatar
Chips
Chips is offline
lol...that is so funny! story of my life...I think everything 'to death'.
gd one Hoss
Old 12-10-2008, 09:57 AM
saybel's Avatar
saybel
saybel is offline
I have a friend with 80,000 miles on his, never had a engine problem. He does proper maintenance, but certainly doesn't baby it.
Old 12-10-2008, 10:14 AM
SportyPig's Avatar
SportyPig
SportyPig is offline
I don't remember that member's name either. He posted a complete list of all of the maintenance and repairs during that 100,000 miles. There were a few major items, but for the most part it was just routinue maintenance.
I have almost 50,000 miles on my bike. The only major repairs have been the clutch (total replacement, due to defective spring plate) and electrical system (replaced both the stator and voltage regulator).
Other than that, just tires, fluid changes, and I did wear out the stock hand grip on the throttle side. Oh, and I also have a slight oil leak now from the rear rocker cover gasket. I have the gasket, just haven't made the repair. And the gasket between the carb and intake is shot.
Old 12-10-2008, 12:31 PM
jblank37's Avatar
jblank37
jblank37 is offline
SportyPig, that member's name is Stephan.
Quick Reply: Life Span of a Sportster
