Front Turn Signal Relocating
Old 01-29-2009, 11:00 AM
Radalack17's Avatar
Radalack17
Radalack17 is offline
Default Front Turn Signal Relocating
I'm having troubles relocating my turn signals to my forks. I know it shouldn’t be this hard... I took peoples advice on here and went with a set of brackets from J&P Cycles (http://www.jpcycles.com/productgroup...4-84B9155EBA9A). But my stock turn signals wont fit right with the brackets. Did anyone else have to use washers as spacers between the bracket and signals? Or am I doing something wrong?
Old 01-29-2009, 11:19 AM
capttawes's Avatar
capttawes
capttawes is offline
Yes, if not using spacers or washers the slope of the signal housing will not properly clear the mount allowing it to tighten down. I have these mounts and initally just ground the mount down a little to fit but have since just used a thin lock washer as a spacer to keep the signal housing from turning once tightened and it fits fine.
Old 01-29-2009, 12:13 PM
hogsport's Avatar
hogsport
hogsport is offline
I have the same turn signal mounts. They are made for signals designed for tripple tree mounts. I made them fit for mine just fine by grinding a stainless washer on one side to conform to the curve of the signal. You could grind the bracket or signal, but I have found the chrome peels off when grinding surrounding areas.
Old 01-29-2009, 12:43 PM
Radalack17's Avatar
Radalack17
I ended up picking up stainless washers as spacers and grinding down the one side. I just wanted to check to see if others had the same prob.
Thanks for the input guys.
feguy1
03-04-2013 07:46 AM
Zeteo
02-19-2013 04:31 PM
PistolPete83
Dyna Parts
02-05-2013 11:04 AM
mtclassic
05-09-2008 05:25 PM
geo10
07-29-2006 04:37 PM
Quick Reply: Front Turn Signal Relocating
