Wrench size needed for drive pulley change??
I have an '04 XL883C that was converted to a 1200. I wanted to change the drive sprocket to reduce the RPMs at highway speeds. So I bought a sprocket on eBay.
I got my 29T sprocket today and pulled off the sprocket cover to see what size bolt holds it in place. I measured 1.905". What size is this exactly??
It's a bit too small to be 1 - 15/16" (1.9375") and too big to be a 1 - 7/8" ( 1.875").
Is it metric?? 1.905" = 48.387mm
What size do I need?? I don't have a larger boxend wrench. Do I need one or is there something else I can use??
Thanks
Thanks
Went out and picked up a 1 7/8" socket today - expensive sucker at $26!! Removed the rear muffler, and took the cover off. Removed the smaller hex screws and the lock, then tried to turn the nut (clockwise) with the socket to loosen it. Won't move.
This bike had been stored outside by the first owner and there was a lot of oxidization on the aluminum parts. I've also found a bit of rust, including quite a bit on the aforementioned nut.
I sprayed a little bit of WD40 between the nut and threads, and a little between the nut and pulley face. I then placed a rag at the bottom to capture any excess. Don't want any on the belt!!
Gave it about an hour and tried again. No good. Fired up a small propane torch and heated the nut a little bit and tried again. Nothing. I then just sprayed some more WD on the nut and closed up the shed for the night. I'll let it soak for a while.
I have the bike on a lift and it's a bit difficult holding the pulley still. I'm engaging the rear brake to prevent the pulley from turning, while attempting to loosen the nut. I think I'm gonna lower the rear wheel to the ground and let the weight do the work for me.
For as quickly as I progressed, I thought I'd be done in about an hour. Guess I was wrong!!
What fits what
Torx T25 control housing screws
T27 clutch inspection cover
control clamps
T40 front brake disk
front wheel hub plate
T45 rear brake disk mounting bolts
fork bracket pinch screws
Allen 6 or 7 mm fork damper tube screw
5/32 sissy bar mounting screws
primary chain inspection cover screws
3/16 primary cover screws
rocker box cover screws
gearcase cover
sprocket cover
sissy bar side plate mounting screws
1/4 front fender bolts
handlebar clamp bolts
eyebrow bolts
coil bracket bolt
left footpeg mount screws
rear master cylinder mounting screws
belt guard mounting screw
primary adjuster screw
5/16 upper engine mounts
front axle pinch bolt
3/8 timing plug
Hex Head 5/16 heat shield worm drive clamps
brake line mounting clips
horn mounting bracket screws
3/8 voltage regulator mounting screws
7/16 coil mounting screws
battery strap nut
brake pedal adjustment screw
10mm horn mounting nut
battery terminal screw
throttle cable adjustment jam nut
1/2 front fender bolt nuts
enricher bracket
front directional signal mounts
mirror mount
coil bracket bolt
brake pedal adjustment screw locknut
9/16 lower front engine mounts
upper shock mounting bolt
belt tension adjuster screws
upper front engine mount screws
rear engine mount bolts
5/8 front directional swivel nut
spark plugs
11/16 lower front engine mount flange nuts
3/4 front axle nut
lower shock mounting bolt
headlight mounting bolt
7/8 primary chain adjuster screw locknut
15/16 rear axle nut
stem bolt
1 3/8 fork tube cap
Twelve Point 3/8 caliper banjo bolts
rear master cylinder banjo bolt
7/16 front master cylinder banjo bolt
1/2 head screws
Phillips #1 headlight clamp ring
directional signal lens screws
taillight lens screws
#3 ignition module cover screws
#4 air cleaner cover screws
All text and images Copyright © 1995-2006 D. Mansfield. All rights reserved. Absolutely no reproduction allowed without prior permission from the author. Disclaimer: This page is not associated with the Harley-Davidson Motor Company in any way other than a fondness of their products. Harley-Davidson, HD, Harley, and Sportster are among the trademarks and service marks of Harley-Davidson that may appear in this Web Site and that are registered in the United States and other countries.
control clamps
gearcase cover
sprocket cover
eyebrow bolts
coil bracket bolt
3/8 timing plug
battery strap nut
enricher bracket
mirror mount
coil bracket bolt
spark plugs
3/4 front axle nut
15/16 rear axle nut
stem bolt
1 3/8 fork tube cap
1/2 head screws
