Nightster Turn Signal Options
Old 12-31-2011, 06:16 PM
meev's Avatar
meev
meev is offline
nice!!
Old 01-21-2012, 07:57 AM
specterindustries's Avatar
specterindustries
specterindustries is offline
Originally Posted by bdavis310
When I chopped my rear fender I took the legs off of the rear turn signals and directly bolted them to the chopped frame and fender. I love the stubby look a lot more.
Initially I had used a relocating kit to move my front turn signals to the forks below the headlight. I wanted to do something else with them so I moved them to the frame, just below the horn in the front. Surprisingly to me, they still stick out around the forks and you can see them. I thought for sure they would be blocked but I tried it anyway. I don't have a pic right now but might post one in an edit.
What size bolts did you use in the back, and how/where on the frame did you mount the front...thanx
Old 05-27-2012, 09:59 AM
JakeCheez's Avatar
JakeCheez
JakeCheez is offline
I am trying to remove the back signal 'arms' and only have the light housing like in bdavis' picture. Not sure if I need to put in a spacer like on the factory bolt......
Old 05-27-2013, 01:24 AM
mr_bungle's Avatar
mr_bungle
mr_bungle is offline
so how is the ride with the struts? my ride sucks *** it is with the regular seat and shocks i feel all the bumps . i figured the spring seat and struts couldn't be and worse . so how is it ? is it worse ? or the same ?
Old 05-27-2013, 03:46 AM
hogdiver96's Avatar
hogdiver96
hogdiver96 is offline
Joker Machines all the way.........
Attached Thumbnails Nightster Turn Signal Options-rear-shot.jpg   Nightster Turn Signal Options-img_1849.jpg   Nightster Turn Signal Options-img_1855.jpg
reitman
06-26-2013 02:02 PM
Thorshammer
09-09-2012 12:48 PM
cloudsrest
08-31-2012 05:38 AM
the reverend
08-29-2010 07:29 PM
NIGHTSTER24
08-11-2009 10:17 PM
Quick Reply: Nightster Turn Signal Options
