Drive Belt very tight when warmed up
My drive belt is mighty tight when it's hot. Tight as hell. Tighter'n a banjo string on steriods.
When it's cold it's pretty tight too. I do think it flexes up about 1/4" like the book says.
Wondering about other sporties....do you guys check out the drive belt when it's hot? Do your belts get really tite when hot? You ever just press on it to see?
Just wondering if mine is too tight ? I do not have the little tool to check it. The belt looks good so far and mileage on bike is about 3500 miles now.
I have heard of them being too tight from the factory.
Thanks,Pete
Thanks,Pete
Give the belt some credit guys.It has been used on car engine timing applications for years although it was much thinner.Both of the Sporties here have tight as guitar strings when cold.The belt tension should be checked with the rider on the bike.When the swingarm moves the belt tension changes.My neighbor generally got 70-80K on the older belts.The newer ones are 100 K plus.S ervice manual will explain how to properly check tension.If you run it crooked it will wear out faster.But so will a chain drive.Beating on your bike will not get the same mileage from the belt or a chain as someone simply riding.
i think you and i have a simmilar issue....
its called "when nothing is wrong with my sporty find something to worry about"
my buds give me **** all the time, yr porbley fine, enjoy the ride
That's not a wheel bearing. That would be nothing to replace. I was mentioning the bearing on your front sprocket which is inside the tranny.
Most of the new bikes's belt drives make a tinging sound when you walk them forward. This means your belt is too tight. They set it up that way from the factory assuming that the belt will stretch. Problem is, after 1000 miles, it's still too tight. Usually you want to loosen it up just a touch (per HD's specs) but then you want monitor it to make sure it doesn't get too loose.
Hey 95yj......thanks, I realized after I sent the post I had focused on wrong bearing...the sprocket bearing would be a major problem.
I got mine slacked off today. No riding tho. Will ride and get it hot and see what it looks like. I did notice when adjusting it, that I ended up with the left adjuster further forward than the right one (less threads out the back than the right)...they were equal distances when I started. (both, of course were pulling further back when I started). Using the rod method mentioned in the manual, my distances from the axle to the swing arm pivot are exactly the same now. (on each side). I am wondering why this is? Maybe the swing arm bushing is causing it or something. Anyway the belt is tracking ok....laying to the inboard side of the rear pulley, but not hard. What do you think?
Is this common on the adjusters?
Thanks, Pete
Thanks, Pete
