Carb Screws won't come out...
After dis-assembling my 2004 1200C down to the carb, and getting the carb out of the manifold, I tried to get the float bowl off to get to the slow jet (my goal was to replace the 42 slow jet with the 45 slow jet - I have SE II slip ons, and the bike stumbles at low speed, and frequently pops and farts, especially when engine braking. Well, I could not get the freaking screws off to get the bottom of the carb off. I may have stripped one. I tried several different philips heads from my tool set. None worked. Anyone have any suggestions for getting the screws off? They just would not budge!
RE: Carb Screws won't come out...
There's a tool that I've had since the 60's when I started working on bikes and cars and will never be without, it's a hand impact driver, with this tool you put different tips on it and hold in the direction you want to turn and hit it with a hammer. This has kept me from stripping alot of screws, all you need it do do is break the screw loose enough to get it to move then use a normal screwdriver. They are very inexpensive but worth their value.
I have found those four bowl screws, and most all of the other bolts on my 06 883, to be of pretty crappy quality. They seem to be very soft. You might have to try cutting a slot in the head of the screw, with a dremel tool so you can try a flat bladed screwdriver. Or maybe you can get hold of the head with a small pair of vise grips. When you do get them out, replace them with hardened cap head screws. And yes, the bowl screws are metric........... "WAKE UP HARLEY"[:'(]
hand impact....they work great!!!
http://www.sjdiscounttools.com/lis29200.html
I'd be afraid of bangin' on the carb (floats and such being relatively delicate) with a hand impact - I vote for cutting a slot with a dremel and using a flat blade screwdriver to get it off. Then replace the sucky phillips head screws with allen head ones for next time...
ORIGINAL: crash1292
man I was a wrench for over 12years ...it never hurt a thing
