can't find diy threads for tank raise, coil/ignition relocation, exhaust swap
Old 12-26-2009, 03:11 PM
benjamin247's Avatar
benjamin247
benjamin247 is offline
Default can't find diy threads for tank raise, coil/ignition relocation, exhaust swap
Hello all,
I've been searching the forums for some DIY's I want to do for my 2007 Nightster but can't find them. Can someone please post the links for the following DIY mods:
- tank raise
- coil/ignition relocation
- changing exhaust (want to install V&H shortshots myself)
Also, from a range of 1-5 (5 being the most difficult), how would you rate these mods?
Thanks!
Old 12-26-2009, 03:27 PM
RMH1120's Avatar
RMH1120
RMH1120 is offline
https://www.hdforums.com/forum/sport...n-my-take.html
There's a great one I used when I did my tank lift. It's incredibly easy, I'm usually awful at DIY projects. I still haven't moved the coil (and I'm leaving the ignition where it is) but it looks terrific just having those wires tucked.
Old 12-26-2009, 04:57 PM
Nightster Ridester's Avatar
Nightster Ridester
Nightster Ridester is offline
Tank Lift- Difficulty 2
Its easy, got to hardware store find semi thin metal cut it to length desired and drill hole same size as bolt for the Stock tank mount. Buy two more short bolts/nuts same size as the stock one. Bolt together, done
Coil/Ignition Relocation- Difficulty 3
Rip all plastic supports off and zip ties. Unbolt the Ignition/Coil Bracket. Re-run all wires on top of frame tube with the tank propped up. Zip tie wires to frame in desired spot. Make or buy bracket for Coil/Ignition, bolt them onto the bracket and bolt bracket on to Bike
Exhaust- Difficulty 3
Unbolt Stock Exhaust and bolt new one up the same way, just have to play with it to find the order in which to squeeze the exhaust to line up properly
You can do it, if you get frustrated, have a beer, take ole lady to bedroom, come out later and try it again. Then repeat!!!!!!!!!!!!!!
Old 12-26-2009, 06:53 PM
Dango's Avatar
Dango
Dango is offline
Shortshots installation was not difficult at all. If you didn't get instructions with them, they're right there on the V/H site...or right here on this link:
http://www.vanceandhines.com/download/D496IN.pdf
Old 02-10-2010, 02:03 PM
illetrop's Avatar
illetrop
illetrop is offline
Default hey
where did u get the ignition relocation bracket from ? thanks and ride safe !
Old 02-10-2010, 05:16 PM
Nightster Ridester
Made it in the garage
Steel Sheet from Ace
Hack Saw
Measuring Tape
Cardboard Mock-up
and VHT Wrinkle Paint
Should take you a couple of hours if you work on it continuesly (sp?)
Old 02-11-2010, 07:36 AM
illetrop's Avatar
illetrop
illetrop is offline
whats sp ? lol
Old 02-11-2010, 07:53 AM
schumacher's Avatar
schumacher
schumacher is offline
Originally Posted by illetrop
whats sp ? lol
spelling
Old 02-11-2010, 09:31 AM
kahaone's Avatar
kahaone
kahaone is offline
tank lift:
https://www.hdforums.com/forum/searc...archid=4057854
coil relocation:
https://www.hdforums.com/forum/searc...archid=4057861
exhaust swap:
https://www.hdforums.com/forum/searc...archid=4057866
There are plenty of threads here, if you know how to use the search function. I used to have a difficult time using it, as I am not very 'puter savvy. But now I just use the advanced search feature, so I can just look in seperate forums. Such as the links above, they are all from just the Sportster section. That makes it much easier to find what you are looking for.
Old 02-11-2010, 11:36 AM
PKS98S's Avatar
PKS98S
PKS98S is offline
How does raising the tank affect the fuel capacity???
Quick Reply: can't find diy threads for tank raise, coil/ignition relocation, exhaust swap
