Shifter Peg Modification
Hi,
I am looking to change out the stock shifter peg on my 2010 Sportster 1200L with a Willie G. Skull peg.
I got the peg I wanted to change out the stock with at the nearby HD shop, but after making it home I don't think I had the right size to remove the stock screw.
What size will I need to get to remove the stock screw from the shift lever?
Thanks.
Thanks.
Sorry I can't remember the screw size but make sure that you heat it up before removing, it said to in the instructions but I ignored it and snapped mine off and had to drill it and remove it with an easyout. The type of locktite they use at the factory will not release without heat.
Garemlin
Nov 14, 2013 02:48 PM
DWCSPORTY1200
Feb 6, 2009 08:33 PM
