newbie question, what does stage 1 ecm calibration mean?
MechsHands, yes I read that response, but Krakanator thinks that a stage 1 is mechanical mods (air cleaner, exhaust), but others think that stage 1 is an actual change to the ECM settings on the bike. I tend to agree with the others.
MEGALifted, thanks for the comment. So it sounds like your setup is V&H exhaust, SE heavy breather, and stage 1 ECM download, is that correct? Did your dealer perform this work, and is this setup what they recommended for you? My dealer seems to think I need a SE tuner, not just a stage 1 download. Beautiful Iron btw.
harleydude49, thanks for the comments.
Aires59, thanks for the comments.
And thanks for the compliment.
Stock or stage 1 1584 street legal
on the website you are referring to-v$h, when they ask that question they are talking about your ecu. stock or stage 1-so they can provide the correct map.
i believe that a fuel pak will work better along with a stage 1 download due to the fact fuel pak does not sffect timing or rev limit- where the stage 1 does-so with that combo fuel pak + stage 1 you are getting the best of both worlds. there are however tuners that do both timing and afr- in that case stock ecu would be better.
as far as the cost of the dealer download to ecu, its about 235.00. good luck and welcome to this world. ps get ready to have people tell you fuel pak is junk, to get pcv-then someone will say pcv's are no good get sert. etc etc etc. fuel pak will work fine with your setup....imho
Sagostino
07-26-2014 02:49 AM
freddy.dj
06-13-2007 05:58 PM
2009, advantages, calibration, davidson, download, ecm, ecu, harley, hd, motorcycle, recalibrating, recalibration, sportster, stage, stock
