nitrous oxide
Old 06-13-2005, 03:29 AM
oldrlh's Avatar
oldrlh
oldrlh is offline
Stage III
Default nitrous oxide
l'm interested about any views regarding nitrous kits, results etc on iron & evo
Old 06-13-2005, 04:00 PM
SKJOLD's Avatar
SKJOLD
SKJOLD is offline
Default RE: nitrous oxide
I was thinking about the possibility as well. In theory, an ironhead might be able to handle the nitro because iron has a much higher melting point then aluminum. Not sure it is a good idea an an evo motor exept in very small quantities for quick bursts as aluminum melts very quickly.
Old 06-13-2005, 09:03 PM
monkyman's Avatar
monkyman
monkyman is offline
Personaly, I wouldn't mess with it. It can cause some serious engine/gasket/warping issues if not used/installed properly.
Old 06-13-2005, 11:43 PM
DWSPhotography's Avatar
DWSPhotography
DWSPhotography is offline
You could run a setup like this... [8D]
Old 06-15-2005, 05:46 PM
SKJOLD's Avatar
SKJOLD
SKJOLD is offline
This post has got me thinking now. The new 2 piece fat bob takes I have on my bike now gives me a neat little spot to hide a small nitrous bottle where nobody will even notice it right inbetween them.
I know that most problems with nitrous occur when too big of a boost is used for the fuel system. And a stock fuel system can handle a small boost with no problems if properly installed. How much of a boost would a small nitrous system properly installed give an Ironhead?
Almond farmer
04-07-2017 01:57 PM
ironevo73
10-25-2013 09:35 PM
Fergy1940
04-14-2012 11:13 PM
Trex
04-08-2010 05:58 PM
nacomedian
Custom Models
08-13-2008 09:17 AM
Quick Reply: nitrous oxide
