iron head vs EVO
Either a 1980 1000cc iron head or 1994-1999 EVO.
Discovered the 1000cc IH engine weight is 7 lbs > EVO 1200.
, if that makes any difference.
The trans shifter mechanism on the 5 speed EVO appears to be superior to the compression spring loaded IH 4 speed.
What are the pros & cons between the two configurations?
Cycle trader shows only a hand full of IH in the entire country, while sixty five, 94-99 , 883/1200 in the entire county
This question must have been ask many times in the past.
It's also much easier and cheaper to find an Evo that is good to go. It's a rare day to find an ironhead that's not expensive that you can just hop on and ride. They've all been beat to **** by handfuls of owners.
Evo is a nicer daily driver.
Ironhead has more character.
Parts availability is about the same, although finding a mechanic versed in Ironhead is a lot harder. Dealerships will still work on an Evo because it's still in production.
Does he want to ride the wheels off the bike, Evo it is.
IH's are getting expensive and they are finicky, even when they were new. Others will tell you how great they can be, but I can relate to you my experiences, they can be a real b**ches, even after you throw money at them and do all the right things. Very challenging bikes, again my experience and sorry to all the IH lovers.
Now an Evo Sportster is the ultimate beat the heck out of it, put it away wet, abuse it like you stole it and she still will never let you down. You find one that was reasonably well taken care of for under $3k, and the thing will go for another 50k miles. Very well engineered machine that is very hard to kill, I have been trying to kill mine since I bought it new in 1991, still going strong, motor has never been apart, ever. The MoCo did good with those bikes. Look for one 1991 and newer, gets you a 5 speed and pony up for a 1200. 883 will leave you wanting for a 1200.
Good luck with your decision.
The Evo appears to be the more economical choice compared to the iron head.
Grandson probably does not have any association with vintage iron head XLs
prefer the 93/99 era because of 5 speed and rebuildable crankshaft/flywheel assembly compared to 2000XL & up
1980 IH located(basket case)only has frame w/o rear fork, matching engine case with sound rod clearance & only main trans shaft and trap door plate, no counter shaft or shifter assembly, no primary, no gear cover, no primary cover
have a 71-76 IH gear cover but does not fit 80 case
already have most of the other parts
The '79-'81 Ironheads would be my last choice, anyway (unless I was building a tracker or cafe racer). They lack the good looks of the '78 and earlier models, and lack the early EVO body parts interchangeability of the '82-'85 models.
When it came time for my daughter to get her bike, I steered her away from the Ironheads, not because I don't love them, but I knew that she needed a daily rider as her ONLY transportation.
She has 1998 Sporty. She loves it. She can, and does, work on it herself, but it's no where near as much work as it takes to keep Old Iron running.
I see from your last post that you are leaning away from the 80 Ironhead, I would as well. There doesn't seem to be enough of it there unless your grandson loves to wrench.
