Help, my oil lamp is on!
Just installed screaming eagle supertuner and v&h exhaust. After the ride home from my dealer the oil lamp went on. The engine heat and temperature seemed fine, but i checked the oil and it was skimmy. Almost like it had started boiling.
Has the H-D tech tuned my bike incorrect or is there some electrical problem because my engine temperature seemed fine?
Btw, it was 70 degrees outside today and i was not driving in traffic or letting the bike run on idle.
Thank you
Thank you
Thank you
Thank you
Thank you
Thank you
It's a 2010 sportster forty-eight with 900 km on it. I noticed that the engine was ticking louder than usual before the oil lamp went on, but it might just be my imagination.
The empty gas tank light also went on suddently right after i had filled her up. I have installed dragbars and a joker machine airfilter on the bike. Now my dealer is saying this might void the warranty.
But is the oil supposed to be all foamy and skimmy? Is this normal?
Thank you very much
Thank you very much
I would check the oil pressure with a gauge before running the motor anymore.
The oil pressure sending unit is at the front of the motor, and is set at something like 5 psi, that makes sure the light does not come on at hot idle, so its almost useless.
The sending units can go bad, and/or leak.
I would unscrew the sending unit and screw in a fitting that allows a gauge hookup, I use an old air conditioning pressure gauge set to measure oil pressures.
Some oil foams up more then others, but the pressure needs to be checked.
Brett
Brett
Thank you very much
Thank you very much
Check pressure with a gauge. Ignore everything else until you know the oil pressure is okay.
The only sure fire way of accuracy is learning what fuel mileage you get and using your trip odometer. Then you will know your range. Just be sure to reset it when filling up. Each rider and bike will get different mileage.
MH
Excuse my bad english! By skimmy i meant the way skimmed milk is when you shake it. Probably not the best way of describing it. Anyways, thank you for your inputs. I'm going to take it to the dealer and have them check the oil pressure. Hope there is no big problems, just a electrical fix or something
Sindre
Sindre
