oil tank leak
Any thoughts?
OK, old thread but I just had my oil tank blow out. It blew the cover off and across the garage about 5 feet. I've ridden in very cold weather but from the description above I'm guessing something froze? Not sure what, this is a stock 2006 Sportster 1200 low with 98,500 miles.
Can anyone explain in lay-man's terms what happened or at least what I should look at replacing besides the tank?
BTW the tank blew at the seam on the outside just under the fill neck.
Thank you
Thank you
Received 2,189 Likes
Thank you
Thank you
