Guess I won't be doing the poker run
I was relocating the coil/ignition as well as lifting the tank. I got the coil all set up and put the spark plug cables back on. Started the bike up, and...only one cylinder was firing. I assumed it was the cable, so I put my old ones on. Same problem. Then I flipped them, same problem. I swapped the plugs, too. No joy.
All that starting/stopping of the bike drained the battery. I found there was a cable that managed to become disconnected which I can only assume was the problem.
I went looking for my battery charger and remembered that I left it in a friends truck a couple weeks ago after lending it to someone. He's gone for the weekend.
I was supposed to do a poker run tomorrow in support of Breast Cancer Research, but I guess that won't happen.
Along the same lines, I'm thinking I can maybe get some booster type cables and have a friend boost me with his bike. I hope that works.
