gas mileage drop
Old 12-04-2010, 08:04 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,644 Likes on 3,882 Posts
Default gas mileage
It can easily vary this much. At 80 mph 10 or 15 mile head or tail wind can make a big difference. I am also amazed how fast people drive these bikes. Harley says the maximum speed on these bikes is 80 with 2up and 90 solo. Slow it down and you will get a lot better fuel mileage. I usually average about 60 and fill up ever 100 on the trip. Usually takes touch over two gallons
Old 12-04-2010, 08:43 PM
elkhunter719's Avatar
elkhunter719
elkhunter719 is offline
Default Mileage sucks
I never get anywhere near that type of mileage. My low fuel light comes on at 112-115 miles regularly and I put in 3.5 gallons. That's a little over 32mpg. I don't ride real hard and it's mixed driving. So should I be concerned?
Sorry, didn't mean to steal this thread.....
Old 12-04-2010, 08:45 PM
Faast Ed's Avatar
Faast Ed
Faast Ed is offline
winter fuel.
Old 12-04-2010, 08:48 PM
32vld's Avatar
32vld
32vld is offline
Speedometer accuracy is not the issue because if the speedo is off, under or over it will be off consistantly.
So mileage and speed readings will not vary from tank to tank.
I have never noticed a change from winter to summer fuel mileage. Besides I believe most fuels are now 10% all year.
The only variable is that he changed his shift points.
The way he changed his shift points will drop his mileage. There should be no surprise for him.
The only thing is that I hope he has not based his mileage change on one tank full.
Back in the day I had a Chey 283 that would get 22 mpg. One tank full I got 25. I always topped off the tank the same. Why I got 25? Who knows, who cares? The thing is if I based my mileage claim on that one tank full I would not be stating the normal mileage.
Owners manual says fifth gear at 55.
Old 12-04-2010, 08:49 PM
Faast Ed's Avatar
Faast Ed
Faast Ed is offline
Do some research.
Old 12-04-2010, 09:05 PM
badbs101's Avatar
badbs101
badbs101 is offline
Yup, it's Winter fuel. Combined with cold temps, mileage drops considerably. Don't confuse Winter fuel with 10% ethanol blend, they are not the same. Winter fuel may or may not contain ethanol. Now, with that said, if your state or gas station has recently adopted ethanol, that also could be contributing to your mileage drop. Ethanol or Winter fuel, most likely Winter fuel or worse yet, both.
Old 12-04-2010, 10:19 PM
lou1's Avatar
lou1
lou1 is offline
I based my mileage drop over 6 tanks of gas. i didnt change my shift points. The bike was running fine before when I shifted at 55 but now when i shift at 55 the engine is lugging and runs fine when i shift around 60 or 65. i guess i did change my shift points but for a reason.
Lou
Old 12-04-2010, 10:56 PM
Jackie Paper
Default tornado
Originally Posted by elkhunter719
My low fuel light comes on at 112-115 miles regularly and I put in 3.5 gallons. That's a little over 32mpg. ....
You must be the tornado out there that Dorothy was talking about ...
Old 12-05-2010, 04:59 AM
Osco's Avatar
Osco
Osco is offline
Account Deactivated
I cleaned my stock Air filter,,threw It In the dishwasher,,
when the OL was at work.
Got a bump In mileage XD
Old 12-05-2010, 06:40 AM
CapnAdventure's Avatar
CapnAdventure
CapnAdventure is offline
Originally Posted by Faast Ed
winter fuel.
True that, plus the colder the ambient temp, the more fuel is burned.
Quick Reply: gas mileage drop
