Blacking out your engine, casing
Old 06-28-2011, 04:20 PM
jaysomethin's Avatar
jaysomethin
jaysomethin is offline
oh yeah i didnt remove anything hence the taping time...
Size:  166.4 KBName:  IMG_0352.jpg
Size:  163.5 KBName:  IMG_0358.jpg
Size:  158.0 KBName:  IMG_0356.jpg
Size:  159.4 KBName:  IMG_0359.jpg
Old 06-29-2011, 02:18 AM
xcore's Avatar
xcore
xcore is offline
Hmm, looks pretty neat, but why did you spray it gloss on one side and matt on the other? Care to post how does the right side of the bike looks like?
Old 06-29-2011, 03:48 AM
REVHAPPY's Avatar
REVHAPPY
REVHAPPY is offline
All talk and no pic's.......Lets see what some of these home paint creations look like
"a roll of green painters tape to the person w/the best home paint job"
Old 07-06-2011, 02:32 AM
xcore's Avatar
xcore
xcore is offline
Gonna do it next weekend after some planning. Do I've to prime the casing after I sand it?
Anyway does anybody know if the HD textured black spray is high temp? Not stated on the can.
Old 07-06-2011, 05:48 AM
opiyone's Avatar
opiyone
opiyone is offline
I used the VHT header paint in flat black. I done the same as Jaysomethin. Tape everything you don't want painted and just paint. I didn't wash my engine off with some degreaser cleaner first to make sure there were no oils. Drinking straws if they fit good would be a good idea and I have read a guy used those little black plastic caps like the ones that are covering some of the bolts on the bike now. I didn't prime anything. I already had tape and paper so the project only cost me $8. Just remember after a coat wait for however long the can says to dry and then repaint. One can was enough for me to paint the whole engine with two coats. Let your engine idle after your done to bake on the paint if you get the VHT header paint.
Larry
Old 07-07-2011, 02:44 AM
HOG_WILD_STEVE's Avatar
HOG_WILD_STEVE
HOG_WILD_STEVE is offline
I'm going to be painting mine too. Can't decide between Rustoleum VHT primer and then black, just straight to black or using the Harley stuff. Any thoughts about some kind of clear coat to protect it a little better?
Old 07-09-2011, 03:55 AM
xcore's Avatar
xcore
xcore is offline
Heyyy, anybody has any feedback after spraying your casings with HD textured black spray?
Sprayed my speedo with that and it traps dirt like a b*tch. Wouldnt want my casing to be trapping sand and all after I done that. Any solutions?
Old 07-11-2011, 10:37 AM
Ergonight's Avatar
Ergonight
Ergonight is offline
Hello Everyone,
I am new to the forum and recently purchased an 07 Nightster. I've been following this thread intently because my engine is in need of a quick facelift and I appreciate all the good info I've gleaned so far. Before I bought it the bike had been sitting in a barn for about a year and oxidation got under some of the paint on the engine casing and block. I plan to pull the engine this winter and really clean it up and repaint but wanted to do something now to make it look better. Anybody have any recommendations for how to clean it up for a quick paintjob as many of you have been doing? I was thinking of taking a dremmel with a wire wheel to the bad spots to remove the chipping paint on the engine (the really bad spots are in the little nooks and crannies around the heads, naturally) but after that what's the best way to clean up the oxidation to ensure the paint sticks? Can I spray the whole thing (not the heads) with some brake cleaner to remove it, along with accumulated road grime and oil? Will that harm the engine gaskets or cause other problems?
I also have many of the case bolts with oxidation and surface corrosion on the heads. Someone mentioned taking them out one at a time. Is it possible to take each one out, clean the bolt head and replace it, then rinse/repeat all the way around the case without ruining a gasket and causing a leak?
Any help on this would be great. Thanks!
Old 07-13-2011, 10:51 PM
gilmour68's Avatar
gilmour68
gilmour68 is offline
Well I picked up a can of VHT wrinkle paint and taped off the engine last Friday. It took about 4 hours to tape and around an hour to spray and touch up.
Here are a few pics...
Attached Thumbnails Blacking out your engine, casing-dark-custom-2011.jpg   Blacking out your engine, casing-dark-custom-2011-1-.jpg   Blacking out your engine, casing-photo0280.jpg
Old 07-14-2011, 12:20 AM
jaysomethin
sorry heres the pics of the finished job... both sides, came out real smooth, that gloss look died right out and has a nice wrinkle black matte finish..
Size:  193.1 KBName:  IMG_0428.jpg
It was just one can of harley wrinkle paint, im not the most mechanically inclined so I didnt remove anything... Still looks perfect after surviving a 9 day 3200 mile road trip:
http://www.youtube.com/watch?v=8NbLlctSuBY
Quick Reply: Blacking out your engine, casing
