Fat front tire on '07 Custom?
You can find some Sportsters, fitting a fat tire on narrow glide front end, but you need some tricks to do so, grinding the fork boots, no front fender etc. Better go with mid or wide glide triple trees... I'm in the process of doing this on my 06' Custom fitting a 120 tire on 18" wheel (like on Superlow), I bought a mid glide conversion kit (includes everything needed to do the conversion - triple trees, axle, spacers etc.)...imo mid glide looks better than wide glide on Sportsters, but it's a matter of personal taste...
Can you still use the stock fender or do you have to do without?
You need to modify the stock fender in order to fit the fat tire...Other options are buying a new one (it would cost you about $100, raw) or go without a front fender, in this case you should better install a fork brace instead of a fender...
https://www.hdforums.com/forum/attac...s-p6110350.jpg
That's my buddy's Iron with Vulcan Mid Glide triple trees...
