Transmission oil level - help please!
I have a 2005 883R and am not very mechanical. I understand I have to check the transmission oil level. I followed the directions in the HD owner's handbook, secured the bike upright and removed the derby cover whilst the oil was still hot. The manual states that the lubricant should 'reach the bottom of the clutch diaphragm spring' My photo and the diagram in the manual do not really tally - not sure where exactly it means. You can see the lubricant level clearly in the photo - is this ok? I know one way to make sure is to drain and fill with the exact amount but I just want to know where the level should be. It was changed at the 5.000 service a few hundred miles ago and looks pretty clean. I believe I am supposed to check every month.
Thanks for your help - here is my photo:
The oil level looks fine.
Unless you find a puddle of oil under the bike, there is no need to check the oil level in the primary/tranny. If the primary/tranny oil level needed frequent checking, they would have included a dipstick.
Just drain & replace with 1 quart at the scheduled interval.
