Cheap easy stash tube.
Old 12-28-2011, 01:02 AM
mhenry's Avatar
mhenry
mhenry is offline
i like it i mioght get me one
Old 12-28-2011, 07:43 AM
XL50#674's Avatar
XL50#674
XL50#674 is offline
Nice Idea and outcome, but i would put a wingnut on the one end so you can open it without a tool.
Old 12-28-2011, 07:54 AM
mreed's Avatar
mreed
mreed is offline
Cool idea. Would also be a good place to put a couple spark plugs if you have a turd Ironhead...like mine.
Old 12-28-2011, 08:56 AM
Gpsjr10's Avatar
Gpsjr10
Gpsjr10 is offline
Looks like alot of work to remove the items inside. Maybe you could solder brass nuts to the inside of the caps then use thumb screw bolts to remove it from the L brackets eaisily. (Maybe solder one of the caps on too) That way your threaded rod isn't taking up most of the room inside the tube.
Old 12-28-2011, 07:51 PM
unclebobis1's Avatar
unclebobis1
unclebobis1 is offline
Is that copper? If so it might end up turning green if it gets wet just sayin
unclebobis1
I forgot to say looks freakin good
Old 12-29-2011, 10:05 AM
Guz's Avatar
Guz
Guz is offline
look awesome, great job !!
Old 12-29-2011, 11:06 AM
8541hog's Avatar
8541hog
8541hog is offline
Originally Posted by dmooth
Yeah, that was my original thought, problem was, the wing hits the license tag nut. I might be able to find a lower profile nut, or trim the wingnut a little. If I could find an "L" bracket blank, with no holes I could definitely make the wing nut work. still a work in progress.
Great idea.
Use the wing nut on the bolt that holds the license, would be easier to remove the L-bracket and cap as a unit I would think.
Old 12-29-2011, 11:07 AM
xFreebirdx's Avatar
xFreebirdx
xFreebirdx is offline
Nothing better than things you've made with your own hands.
Old 01-01-2012, 11:34 AM
dmooth's Avatar
dmooth
dmooth is offline
This is what's great about these forums, the collective conscious that it creates. I like this idea, and you're right I need to free up the space and eliminate the threaded rod. I'll be messing with this some more to refine the design. Thanks everyone for the thoughts, and comments, May the new year bring many safe rides.
Quick Reply: Cheap easy stash tube.
