nightster rear fender led tail light
Easy install, put one on the wifes 48. 2 observations, be sure the underneath of the rear fender where the light mounts is really really clean. It mounts with double-sided tape and before i started i cleaned the foam off that was leftover when i removed the original reflector with goo-gone. Then when that was all off i scrubbed it with rubbing alcohol and also make sure the underneath is clean where ur gonna mount the wire clips which are included in the kit. Also the tape thats on the light itself sticks well but the tape thats on the clips suck, i had red 3M tape in my toolbox so i just replaced the tape on the clips with the red 3M
How is the wiring? plug and play or do you have to hack and splice??
No need to add/replace any fuses - the MoCo one comes with all the necessary connectors - no splicing, just make sure you connect the wires to the wire clips properly. It really looks great.
