Jigsaw to cut rear fender?
I screwed up my stock fender on my 48 & ordered another 1. I'm wanting to cut about 2.5-3" off it before I have it painted. I want it to have the same contour as it is from the factory, just shorter. I tried cutting my old fender w/a Dremel & a 4" cut-off wheel on a grinder. The Dremel made a nice straight cut but I can't make a radius w/it. The grinder was a mess! So can I use a metal blade in a jigsaw to cut rear fender or will it bounce all over the place? Thanks.
Yes, a fine blade in your jig saw will work ... that is what I used to cut my fender. After removing the fender and drinking a beer I cut the frame rails, then reinstalled the fender. I wrapped the fender with blue painters tape, created a template and traced out what I wanted. Drank a second beer and let the jig saw rip !!
Thanks ... good to hear that you like. Hard to see in the pics, but the sides roll rearward with a sight radius along the top. I cut it that way to make the fender more interesting than a straight line from end to end.
