07 1200 nightster
07 1200 nightster
got it 3 weeks ago...now its time to start modding it . never really messed with a harley but after a bit of research and looking at pictures Im thinking a slight tank raise with some drag bars will get me in the ball park I want to be with it. oh yea, and more black. Let me know what you think.
I like my N.
+1 on the more black (painting the engine) because of the black pipes and AC
Also, buy the Progressive Fork springs...I should had done that years ago. @$70. well worth it.
FWIW as a new owner 1) Check the fuse box for previous water intrusion 2) Check the clips for the side cover over the battery 3) Check motor mount bolts especially left side upper where it attached to the head 4) Check battery ground cable. 5) Check swingarm to frame bolts for correct torque. {On mine I had to retorque the swing arm only once yet have had to retorque that upper motor mount bolt maybe 3 times}
I also believe there was one factory recall for the fuelpump.
