desiding barnett clutch or oem harley clutch what do you think?
well bike is on warranty thank god but i need to deside if i want the harley clutch or barnett i have looked at alot of the posts on here and still cant deside my bike was having the same problem as sportypig. so hopefully some of my peps can give me alittle info on what they think. Any knowledge would be useful thanks.
That's the main reason I wanna go with the barnett but I heard that the longevity is better with the harley clutch is that true.
hi there and where do you get the additional friction plates ?? do you need to order an entire clutch pack from the stealer just for a couple of plates ?????
im in need or the clutch replacement also and am also trying too decide between energy one and a S eagle clutch pack .
if i can just do a a standard pack and change out the riveted plate that would be great
I got it from a friend, methinks he bought a bunch from J&PCycles. You need two steel plates and one friction plate. I saw one smartass in another forum claimed the clutch will not work properly with such an upgrade because the clutch spring goes out of its designed working range. I measured the thickness of the spring plate depressed and released. When released it's thicker than three additional plates, when depressed it is thinner than three additional plates. Meaning the spring will pressurize the pack just fine, actually even better.
Be prepared to have a snappier clutch, you have to be more precise with your left hand.
