My 48 180 rear conversion pics
  #81
Old 06-27-2013, 06:51 AM
'48's Avatar
'48
'48 is offline
6th Gear
Originally Posted by wachuko
Thank you for catching that! Let me try to find the part number for the Scorcher 11... the one listed is for the 31...
I think the part number for the 180/55 ZR 17 Scorcher 11 is 43200011
  #82
Old 06-27-2013, 07:33 AM
wachuko's Avatar
wachuko
wachuko is offline
Thumbs up
Perfect! I updated my initial post with the correct number.
  #83
Old 06-27-2013, 07:37 AM
Kontankerous's Avatar
Kontankerous
Kontankerous is offline
Originally Posted by c0jones
The Softail Crossbones had 17 rear & 16 front.
The crossbones rear wheel is 17x6 and comes with a 200 tire. That actually will require a chain conversion, some modification of fender struts, and various grinding depending on how low your rear sits. This thread and most questions here are for a direct swap with minimal to no modifications. That is why the 17x4.5 Street Bob wheel works perfect here.
I will say though, it looks bad *** on a Sportster.
  #84
Old 06-30-2013, 04:13 PM
XL-Power's Avatar
XL-Power
XL-Power is offline
Would a 16X5.0 need much more modifications to fit than a 17X4.5?. If possible?.
  #85
Old 07-05-2013, 04:46 AM
XL-Power's Avatar
XL-Power
XL-Power is offline
Anyone?....
Would a X 5.0 rim even fit?. It's a 1/2" I know but someone might have tried this combo?.
  #86
Old 07-05-2013, 07:29 AM
Rog48's Avatar
Rog48
Rog48 is offline
Ive been following this thread.......something I may do this winter. But I dont want laced wheels. I see I can get some 16X5s though. I dont see why it wouldnt work.......the tire is wider than the rim. You would have to do some spacer work though.
  #87
Old 07-06-2013, 03:41 PM
XL-Power's Avatar
XL-Power
XL-Power is offline
Those 16X5 wheels just wonder about that hub, the hub seems huge...
  #88
Old 01-24-2014, 10:26 PM
HeadRush's Avatar
HeadRush
HeadRush is offline
6th Gear
This certainly seems to be an economical way to put a 200 on the back of my 48. Older post, any others try this swap? Was the stock axle reused?
  #89
Old 01-25-2014, 04:40 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,854 Likes on 2,420 Posts
This is probably the best post on this subject! Nothing better since.
  #90
Old 01-25-2014, 09:57 PM
kenslen's Avatar
kenslen
kenslen is offline
and he's using the stock 48 rear fender?
Quick Reply: My 48 180 rear conversion pics
