Sparkplug question
Old Mar 20, 2013 | 03:19 PM
lo-rider's Avatar
lo-rider
You should put together a very basic tool kit, just for the bike. And buy the service and parts manuals. Even if you don't know how to use them, someone knowledgeable can assist.
Old Mar 20, 2013 | 03:31 PM
atwa's Avatar
atwa
I picked up the service manual when I swapped the bars but I agree I need to put together a better tool kit than my screwdriver, knife, and Allen wrench lol
Old Mar 20, 2013 | 04:39 PM
cmc seabee's Avatar
cmc seabee
Make sure you put a light coating of anti-seize on the spark plug threads to keep them from galling the threads in the heads. It will make it a lot easier to remove them next time. Also a good idea to torque the plugs when installing.
Ride safe.
Old Mar 20, 2013 | 10:27 PM
laffin gas's Avatar
laffin gas
is it also possible for you to plug a battery tender in? that may help keep your voltage up perfectly for cold starts. if you had a tender plug connected to the battery you could easily check the voltage in the morning if you had a volt meter....you can get a cheap one at harbor freight that will at least let you know if you are on the low side in the morning. plugs should help and also maybe you have been getting crappy fuel....try a different gas station. plugs are a cheap thing to change and bad plugs will make the bike not want to start and when running it may not run as well as it should.
good luck and hope you get it sorted out
Fenian32
Exhaust System Topics
30
Dec 21, 2013 08:58 PM
Chunker
May 28, 2013 01:32 PM
Bbrown18
Aug 12, 2012 04:45 PM
maddog76
May 20, 2011 09:31 AM
RidemyEVO
EVO
38
Feb 8, 2011 11:47 AM
