180 60 16 on a solid rear wheel
'08-13 FXDF FAT Bob rear wheels are 16x5.00 & use a 180/70-16 Dunlop D427
'06-13 FXDB STREET Bob rear wheels are 17x4.50 & use a 160/70B17 Dunlop K591
('06-07 can probably be used after changing bearings from 1" to 25mm)
Maybe for a 2004-2013...
On a '94, it's not gonna be an amateur project.
Your bike came with a 130mm tire, a 180mm is 2 inches wider.
Do you have more than an inch of space on each side?
The bearings would need to be changed from 25mm to 3/4".
The pulley/sprocket/rotor will probably not line up.
Someone here just posted a thread about using a 17x4.5 wheel and a scortcher 180mm tire and it fit with no mods, besides using spacers to center the wheel under the stock fender. If i find it ill post it, but i believe you were right (street bob) not fat bob.
I can't say for sure because i have never done the mod, but am looking forward to doing it.
