High flow filter under stock cover
I'm looking for a high flow assembly that fits under the stock air cleaner cover for my wife's 2013 1200c. I have an S&S stealth on my FLXH, but the same type of assembly from S&S for a sportster requires a different cover with a center bolt. Arlen ness has something close but I don't think it has a K&N filter. Any ideas?
drill the backing plate!
back in the 70's, when the epa was tighting emissions, we would remove the air cleaner cover, and the filter, then remove the backing plate, and drill it out around the outside of the filter! you can and i have done this to the new harleys, you still need the stage one download! cheers from montana
Yeah, you can do it with the stock cover....
http://www.cruisercustomizing.com/bi...part/AN-18-825
Does this kit have the K&N filter or just a red paper filter? I was originally going to use this kit, but can't find a definitive answer.
