sportster, 2 holes not 3?
so the sportster has 2 holes not 3? engine/ oil tank and then the other one that I assume is called the primary? is this right?
so I shouldn't use gear oil in the primary(or whatever its called) of my 2011 sportster? at least that is what some say.
I was planning on putting a good synthetic motorcycle motor oil in the oil tank and the a good synthetic gear oil in the other (were you take the inspection cover off and fill to the required point). I know everybody has there preferred brands so im not getting into that. I just want to know if I can put a good gear oil in the "primary/transmission area of the sportster?
im lost
im lost
2 holes
1: your primary is you oil tank which you can drain through the drain plug at the bottom of the bike
2: your gear oil...you drain your gear oil through a nut right under the derby cover...to fill your gear oil, take off the derby cover where the gears and clutch is located and add the gear oil in there, either that or the inspection cover where your primary chain is located
Motor oil in oil tank, and gear oil in derby/inspection cover...Don't mix
Hope this helps
Hope this helps
stockglock....maybe sure you go to harley to get your oil filter...DON'T put some piece on there!!...i had my dad go and pick up a filter for me once and he got me some cheap piece that almost caused my engine to explode...he shouldve known better because he had a sportster but now has a dyne low rider...
that a$$hole would've never put that on his bike though smh
im lost
im lost
2 holes
Hope this helps
Hope this helps
by the way...I have a manual on order so I don't have one to look at yet. thanks everybody.
