Need help with engine VIN
I have searched Internet and have been able to learn some about my motor but still have question.
My vin# (star)CAMR907789RE(star)
From what I can decipher it is 1994 XLH883, production number 907789, but what does the "RE" signify about this engine?
I called local Harley shop and they were no help, so I have turned to HDForums to help me out.
Any info would be appreciated.
Thanks,
John
Ps, do not have frame, looking to install on aftermarket frame such as Buell.
Thanks,
John
Whats the frame VIN? That will tell you everything.
http://www.terry-zone.com/tech/vin.php
17 digit VIN on frame. Engine has a partial VIN and the numbering is out of sequence, but you will know if the engine and frame belong together or not.
Frame ID Numbers - 1981 -2000
Example: 1HD1AAK19BY123456
Rog - I have seen the abbreviated engine VIN referenced; such as
1HD1ELK12B2123456 on frame would be ELKB123456 on engine.
But I am confused as to why this engine has "RE" after the production number.
Based on above, original frame number would have looked something like this;
1HD1CAM??R?907789
I am guessing at this point if I am correct.
I can supply a picture if anyone wants to see.
Thanks,
John
1HD1CAM??R?907789
Thanks,
John
R = 1994
E= Manufacturing Plant
E = Buell East Troy Wisconsin, USA.
is your answer
is your answer
From 1981 to present the VIN has been a 17 digit code located
on the frame and ABBREVIATED on the engine
mind u its abbreviated on motor
VIN the first 3 digits are the world manufacturer ID like 1hd 5hd 932
the fourth digit is the weight class 1 or 4 or 5
The next two letters are the model designation
CA = XLH
the sixth digit was the engine type
M = 883 Evolution XL, Twin Cam 103
the seventh digit was the INTROCUCTION period
R = 1994
the VIN check digit which could be 0-9 or X,
6numbers.
next letter was the MODEL year R = 1994
the letter after that was the assembly plant
maybe more clear
CA = XLH
R = 1994
6numbers.
maybe more clear
