vibration from 2500-2800 rpm
Cruising at less than 3000rpm will often result in vibration / lugging. Plus, the throttle is much more responsive at 3500-5000 than it is at 2500 so if you suddenly find yourself needing to giddy up in a hurry, you will have a lot better luck if you are cruising above 3000 than if you are below 3000. For those reasons I never cruise at less than 3000.
Bull. (At least, as far as lugging is concerned. All engines have some harmonic points that cause extra vibration, but that's not the same as lugging.)
When I'm just puttering about I upshift at 3,000 RPM and that doesn't lug a damn thing.
If it was a 100 degree day and I was going up a 10% grade with a 150 pound passenger on the back I might want to keep the revs above 3,000, but for just cruising on level ground she'll be just fine even at 2,300 RPM.
Have fun with that!
I have. Again and again and again.
But I'll post the video of perfectly fine up-shifts at 3,000 RPM for a third or fourth time.
The audio is clear that there's no lugging, and you can easily see the RPM dropping to 2,200-2,300 after each shift. The bike does just fine.
Shifting Example - YouTube
![Icon Eddie](https://www.hdforums.com/forum/images/smilies/icon_eddie.gif)
