UK 2013 Harley Sportster 883 Iron - Build Thread
Old 05-23-2014, 11:51 AM
Doldy's Avatar
Doldy
Doldy is offline
Default UK 2013 Harley Sportster 883 Iron - Build Thread
Hey, Dan here from the UK. I wanted to share the progress of my Harley build so created this thread. I will update as and when progress is made, but I have many plans for the bike, keeping it simple as it should be.
Here is the bike when I took delivery, totally stock standard bar a couple of crappy little parts (fuel tank cap being one of them):
Old 05-23-2014, 12:10 PM
Doldy's Avatar
Doldy
Doldy is offline
First step was to get out to test the ride, but before this I had to flip the mirrors, down size the rear license plate and ditch the fork reflectors.
Old 05-23-2014, 12:25 PM
Doldy's Avatar
Doldy
Doldy is offline
Off came the passenger pegs, and the twin seat replaced by a La Pera solo seat. Really nice quality seat although need to dull it down. I do have plans for a springer seat soon though!
Then came time to fit my v&h short shots, v&h fuelpak and k&n air filter. I forgot to get a photo before stripping the rear fender but here's one for now:
I must add the quality of these items are superb. The exhaust was superb fitment and quality. The air filter obviously was as it should be and the fuelpak made a big difference even on idle when I entered all the values for my set-up!
Old 05-23-2014, 12:30 PM
Doldy's Avatar
Doldy
Doldy is offline
I have my own powder-coated so got these parts finished off in a fine black to match the casings already on the bike:
Derby cover:
Inspection cover:
Also drilled and coated the belt guard. Not sure if ill even put this on at all though:
And made this mock bracket. Also powder coated. With the 5x7 plate:
Old 05-23-2014, 12:42 PM
wachuko's Avatar
wachuko
wachuko is offline
Very nice!! I like the idea of powder coating the belt guard on the same finish as the engine... very cool.
Keep the photos coming.
PS - and the other ride looks great as well
Old 05-31-2014, 02:28 PM
Doldy's Avatar
Doldy
Doldy is offline
Been working a lot the last week so been stuck for time, but managed to get an afternoon off to work on the bike. Here is the progress:
Stripped read for fender strut chop
Painted the ends up to match in with the frame black came out really well and the chop isn't noticeable against the harley finish..
Old 05-31-2014, 02:32 PM
Doldy's Avatar
Doldy
Doldy is offline
Next I stripped the side plastics out from the fender, drilling the rivets out as these will not be out back after. Then masked up my cut lines and went to town:
It came out well, I masked up after cutting and smoothing and used some Matt black spray to touch up the edge, flattened down and matches in perfectly.
Old 05-31-2014, 02:37 PM
kingxirol's Avatar
kingxirol
kingxirol is offline
Thumbs up
It's turning out to be really nice so far. And it's take some BIG ***** to chop a brand new bike like this. I wish had them ....
Old 05-31-2014, 02:44 PM
Doldy's Avatar
Doldy
Doldy is offline
Progressive 11" shocks fitted, really nice quality and perfect fit in ten mins flat:
Next up was to re-fit the rear lights. Drilled out a hole for the wiring as I wouldn't be using the fender strut covers again and want to hide the wiring.
Used some threaded bar to fix the light units. And re wrapped the wiring with harness tape:
I used some thick rubber washers between the struts and the light units. They seated against the struts nicely.
Fitted the fender and tucked the wires up. Refitted seat and this is how it all sat when loaded. I will be lowering another inch on lowering brackets when they arrive.
Old 05-31-2014, 02:47 PM
Doldy's Avatar
Doldy
Doldy is offline
Front indicators swapped out for smoked units. Re-wired and fitted to the forks. Much nicer.
Also fitted the light ring that I powder coated Matt black.
Quick Reply: UK 2013 Harley Sportster 883 Iron - Build Thread
