attempted idle drop method
Was trying to adjust the mix using idle drop and ran into a problem. I could get the idle to drop going lean but never did the engine want to die or drop significantly turning the screw out (rich) even at 4 turns. So I just left it at 2 1/2. Bike seems to run fine like that but when I got it the screw was out 3 or 3 1/2. Not sure what this means, do I need to rejet? No mods besides cutting airbox and removing baffles, bike is 05 883l 2k miles.
The idle drop method gets you pretty close. I've found for fine tuning you need to just ride and check gas mileage/spark plugs to get a better idea of how it is running. Shouldn't need more than a 1/4 turn either way to be perfect from where you set it with the idle method.
