test
Old Jan 17, 2009 | 09:58 PM
WS6 Formula's Avatar
WS6 Formula
Default test
2006 Harley Davidson Dyna Low Rider
Dragonfly Green Pearl & Vivid Black
(Custom paint 1 of 233 only available Jan - Mar 2006)
(Before photos have reflectors and belt guards removed)
**Front End**
*H.D. 2006 Wide Glide 21" front wheel P/N 43563-06
*H.D. 2006 Wide Glide triple clamp upper P/N 46700-06
*H.D. 2006 Wide Glide triple clamp lower P/N 46386-06
*H.D. 2006 Wide Glide axle P/N 40923-06
*H.D. Chrome Tapered Front Wheel Spacer Kit P/N 41410-06
*Kuryakyn Front Axle Nut Covers P/N 1213
*H.D. Tinted turn signal lenses P/N 69304-02
Painted turn signal reflector and internal housing flat black
*H.D. 2008 Screamin Eagle Dyna front turn signal mounts P/N 68266-03
*H.D. Classic Chrome Brake Caliper Insert P/N 44477-99
*Lyndell Z Brake Pads P/N 7195-Z
*H.D. 2006 Deuce headlight (New take off from eBay)
*H.D. 2006 Sportster Custom, headlight mount P/N 67919-96
*Sylvania Silverstar H4 bulb
*Added a bushing between the lower headlight tabs (So tabs will not bend over)
**Hand Controls**
*H.D. Aileron Hand Grips P/N 56425-02
*H.D. Chrome Switch Cap Kit P/N 71804-03
*Added a relay connected to high beam lead to trigger garage door opener
*Routed control wiring inside handle bars
*Routed front frame and console wire harnesses to left side of the bike
*Redressed all harnesses, cables, and hoses
*Removed reflectors, all factory decals, VIN, and emissions labels, and vapor canister
**Tank**
*H.D. 2008 Screamin Eagle Dyna Spun Aluminum Face 4" Speedometer - MPH P/N 67516-04B
*H.D. 2008 Screamin Eagle Dyna Spun Aluminum Face 4" Tachometer- RPM P/N 67522-04A
*H.D. Smooth LED Fuel Gauge P/N 75237-03A
*Tank lift 1.60"
**Engine**
*Arlen Ness Big Sucker I air filter kit P/N AN18-505
*Cut off the original air filter outer cover
*D&D Fat Cat 2 into 1 exhaust with quiet baffle P/N 496-32B
*H.D. Screamin’ Eagle Performance Exhaust Gasket Kit P/N 17048-98
*H.D. Screamin Eagle Race Tuner P/N 32107-01E
(base map # 141NX002 is for 8* injectors but using 25* injectors, +AFR, +VE, +Timing, - Cranking Fuel, - Idle, +Accel Enrichment, - Decel Enleanment)
*H.D. Screamin Eagle spark plug wires P/N 31937-99A
*H.D. 10 Row Oil Cooler P/N 26110-05
Home made spark plug wire supports
*Billet finned timing cover (from eBay seller gregg5869)
*Relocated horn using rear engine mount bolt
*Installed banana jack on bottom of coil cover for battery tender
*H.D. Script Battery Cover Band P/N 66443-06
**Foot Controls**
*H.D. 2005 Forward control kit P/N 49080-03
*H.D. 2006 Polished Stainless Steel Gear Shift Linkage P/N 33815-06
*Removed the original shift lever without removing the primary
*H.D. 2007 Screamin Eagle Springer foot pegs P/N 52317-07
*H.D. 2007 Screamin Eagle Springer brake pedal P/N 42574-07
*H.D. 2007 Screamin Eagle Springer shifter peg P/N 49268-07
*H.D. 2007 Screamin Eagle Dyna Polished Stainless Steel Footpeg Mounting Pins (2 sets) P/N 42679-01
*Grinded down rear foot peg stops so pegs will tilt in more when in the up position
**Rear End**
*Custom Chrome lay down pyramid license plate mount P/N 14199
*Trimmed license plate to fit inside mount
*Kuryakyn Deluxe Smoked Tail Light P/N 4974
Painted LED light face plate and inside of lens sides flat black
*Modified lower belt guard
*H.D. Chrome Tapered Rear Wheel Spacer Kit P/N 41411-06
*H.D. Script Rear Axle Cover Kit P/N 44346-06
*H.D. 2007 Street Glide Air Shocks P/N 54631-02B
**Tires**
*Dunlop Screamin Eagle Rear GT502 180/60B17 P/N 43197-04A
*Rear Fender Inner sideplate brackets x 2 each, P/N 59514-06
*Dunlop 17" Tube P/N 40502-06
*Dunlop 17" Rim Strip P/N 43101-06
*Avon Venom 90/90B-21 FRONT (AV318)
*Dunlop 21" inner tube P/N 43140-80
*Dunlop 21" rim strip P/N 43939-89
Before and After Photos
Cut off the air filter outer cover
H.D. Tinted turn signal lenses with painted turn signal reflectors, trimmed plate to fit into mount
Kuryakyn Deluxe Smoked Tail Light with paint on the inside of lens cover to hide wiring, also painted the face plate of the LED lights
Installing Wide Glide Triple Clamps, Wide Glide 21" wheel, and internal handlebar wiring
Cut open D&D FatCat baffle to pack with fiberglass, quieter and deeper tone, also more low end torque
Homemade ignition wire supports
Old Jan 17, 2009 | 10:00 PM
WS6 Formula
Quick disconnect for Battery Tender, connectors available here: http://shop3.frys.com/product/2379099?site=sr:SEARCH:MAIN_RSLT_PG
Horn relocation
Screamin Eagle Dyna Gauges after original developed its own mind
Cleaning up the wire harness, sleeving available here: http://shop3.outpost.com/product/2281408?site=sr:SEARCH:MAIN_RSLT_PG
Used JB Weld for a plug
Old Jan 17, 2009 | 10:01 PM
WS6 Formula
Trimmed lower belt guard, matched radius to pulley, trimmed lower portion parallel to belt, and cut out triangle to get a better view of the wheel.
Dunlop Screamin Eagle Tire GT502 180/60B17, Low Profile Touring Air Shocks
Old Jan 18, 2009 | 11:01 PM
wyoming55's Avatar
wyoming55
testing
Old Jan 21, 2009 | 08:38 PM
graham's Avatar
graham
test test
Old Jan 21, 2009 | 08:39 PM
graham's Avatar
graham
testies testies
Old Jan 21, 2009 | 08:41 PM
graham's Avatar
graham
trying again....
