The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
Other Devices: FP3 On A Stock Bike?
Old 02-25-2018, 08:23 AM
Sidehacker's Avatar
Sidehacker
Sidehacker is offline
Default FP3 On A Stock Bike?
I have a 2013 Road King that is totally stock. It stalls sometimes at stop lights but starts again easily. The idle seems a little rough to me but I can't remember exactly how smooth it was when it was new. Is there any harm to putting a FP3 on it and giving it a try?
Old 02-25-2018, 08:38 AM
jbarr1's Avatar
jbarr1
jbarr1 is offline
No harm but you shouldn’t expect the FP3 to fix a hardware issue. Check for intake leaks, spark plugs/ wires, codes before throwing a tuner at it and thinking it’s going to hide the real issue.
Sidehacker (02-25-2018)
Old 02-25-2018, 11:31 AM
Ed Ramberger's Avatar
Ed Ramberger
Ed Ramberger is offline
Always verify proper operation of engine prior to adding aftermarket fuel controllers or tuning. The bike should not stall out at stop lights and this should be addressed first.
Old 02-25-2018, 02:37 PM
Sidehacker's Avatar
Sidehacker
This is where I really do need to start. Last Summer the bike started to cut out and miss after it was warmed up and then progressed to get worse to the point that it wouldn't stay running after it was warmed up. I couldn't find the problem and the shop I had work on it found a vacuum leak at the intake manifold and head. They said the factory installed the seal or gasket wrong and it was doubled over on itself. I rode the bike until riding season was over but I think I should buy all new intake gaskets and seals and pull it apart myself and replace them again. Thanks for the advice.
Old 05-24-2018, 08:56 PM
Sidehacker's Avatar
Sidehacker
I finally had time to work on the bike, took some vacation from work. New plugs and wires fixed this problem! Thanks again. I'm still going to put an FP3 on because I like the capability to read codes with it and from what I've read they can adjust for gas quality and other variables that the factory ECM does not.
Old 05-24-2018, 09:33 PM
firehawk6's Avatar
firehawk6
firehawk6 is offline
Received 7,417 Likes on 2,945 Posts
My son with his '17 Iron, and myself with my '17 Superlow both found the completely stock bikes ran much better reflashing with V&H stock MAP compared to the factory one.
I'm not willing to try the autotune feature as some have had good results, and some have had major headaches trying it. The bike runs great, and I'm not messing with a good thing...
Sidehacker (05-25-2018)
Old 05-25-2018, 06:56 AM
Sidehacker's Avatar
Sidehacker
Thanks, I'll give that a try when I put it on.
Old 05-25-2018, 04:41 PM
Gozzie's Avatar
Gozzie
Gozzie is offline
You can copy the map you like with a new file name and try auto tune with that map. If you don't like it you can always go back to the one you like.
Old 05-25-2018, 08:07 PM
Sidehacker's Avatar
Sidehacker
I'll keep that trick in mind too. J&P has Vance & Hines products on sale this weekend, 10% off. When I'm done here I'm going to their website and order it right now.
Roadflyer
05-15-2017 09:07 AM
jokenroll
EVO
28
09-25-2012 10:50 AM
2006ultra
02-13-2012 02:36 PM
eviltwin415
05-25-2011 12:04 AM
mustangman90
07-03-2010 04:53 PM
Quick Reply: Other Devices: FP3 On A Stock Bike?
