DYNOJET: PV settings to make bike start easier
jbarr1 (04-08-2022)
Basically what does your bike do? The M8 got revised ACR that work properly so the engine should spin over freely. If it does not then its and ACR issue and has nothing to do with tuning unless they turned them off. Next would be if it cranks fine but them starts hard it depends on the tune as it could be fuel or timing at that point but removing timing from the low RPM high kPa area isn't going to help it.
It's not the ACR's themselves. It is a problem with the way the software works in the ECM's. The ACR's are not told to work until the ECM finds where the engine is at so it can sync itself to it. This takes a couple of engine revolutions to occur and if your high compression build stops the starter dead in its tracks that cannot happen.
WKNDS (04-13-2022)
Can I simply disable ACR in Mastertune when I program the ECM, then disconnect the ACR wiring from the BCM and control
them with a Momentary button mounted on my left-side handlebar ?
Thanks for any insight,
T.
Sorry to re-hash this, but this got me to thinking what would be the 'easiest' way to manually control the ACRs in the older TwinCams ?
T.
T.
WKNDS (06-04-2022)
