For guys that run big Flags..with pics.
It would seem that I've built a pretty sturdy set up. Had a guy riding behind me last weekend, and he said the pole was rock steady up to about 50 MPH or so, then it started to dance a little bit under the stress of the flag. Briefly had it up to about 65 or so with a 20+ MPH headwind on Saturday afternoon, and all was well. Not anticipating flying my flag at highway speeds, but it's good to know that the pole and mount is up to the task should it be necessary from time to time.
Received 5,401 Likes
If you want to keep your flags longer and stop the fraying on the ends.. go to Walmart and get a small bottle of Liquid Seam Sealer - lay your flag out on a table - put news paper under the flag along the end seam - SOAK the seam to about an inch inboard - all along the seam - flip the flag over and do the same for the other side - this Will seal the trailing edge - I have done this to my 3x5 and have run it many times - I have a set up by Al Rock - Gilroy, CA - no longer makes flag mounts - his were sold Stainless steal - mounted to receiver - poles were also stainless steel with hardwood dowels run thru the poles - great set up and solid as the day is long... I can run mine at freeway speed but will not (switch to 2x3) off the freeway and 55 max - run the 3x5 all day long
RoBB Randolph (01-19-2021)
Per the picture in my signature:
- 3x5 flag from Gettysburg Flag Works.
- added extra grommets as the OP.
- 1.5" galvanized pipe painted with silver Rustoleum
- top final from a Costco flag pole
- threaded eyes bolted through the pole
- flag attached to eyes with screw shackles
- Rivco flag mount on a Rivco hitch
It has survived speeds up to 70. Some of our processions on the freeway tend to slinky. And with me usually bringing up the rear...well we get going pretty well.
Oh yeah...the picture was with a Costco aluminum pole, with the rotating plastic holders. That did not not hold up. So, it was replaced with the flag described above.
From personal experience: A 3x5 flag acts as a sail. You will feel the drag at highway speed and it will move you on the road. As per my previous post: Stick a 3x5 out your car window and see if you can hang on to it at 60 mph. That's the same force that's on the back of your bike! I have personally followed another PGR rider who had a flag pole made from water pipe and watched it fail from vibration. It looked like a tree falling in the forest.
Here's our safety guidelines. Scroll down to "Member guidelines".
http://www.mnpatriotguard.org/safety...Guidelines.pdf
If your flag pole fails and causes injury to a rider behind you, you are liable. What part of that needs explanation?
P.s. In case some might think I'm just talking out of my tailpipe, I ran an insurance agency from 1980 to 1992.
I remember seeing where displaying a 3x5 flag at highway speeds greatly contributed to clutch wear. I think Harley eventually gave in to this guy though...
https://jalopnik.com/harley-denied-t...but-1584531157
Honest answer. If an organization "endorses" the flying of a flag that they know could come off at highway speed, and injures a following rider, who is the attorney going to sue? The rider flying the flag, or the organization who "allowed" it? Well, the attorney will sue both, and collect from the one with the biggest policy.
