Finally did my breather bypass (pics included)
#691
Anybody tried to terminate the vent hoses with a metal end and have it drip the **** on a hot part of the header to burn it off? Just wondeing out loud, haven't tried it yet. I get about a tablespoon of really foul smelling water after about 200 miles in my catch can and can't see any down side other than discoloring the header, but it would be hidden under the heat sheild.
#692
Received 1,738 Likes
#693
Not sure if I'm crazy about that idea but I get the same stuff in my catch can. My Ultra Classic 103 cu. in. motor is a "spitter". I have just resolved myself to clean the catch can often, which is no big deal. Removing the can is a possibility but don't want crap dripping on my garage floor.
#694
SteveDotWorld (02-12-2023)
#695
scott_0 (02-13-2023)
#696
#697
I like the clean look of this!!
[QUOTE=Jake The Glider;21067244]Here’s my breather bypass setup:
Where did you get your vacuum connectors? What type of hose did you use? I am concerned about the heat on this set up, i want to make sure no mistakes on my part are made! Thanks for posting!
Where did you get your vacuum connectors? What type of hose did you use? I am concerned about the heat on this set up, i want to make sure no mistakes on my part are made! Thanks for posting!OTE]
#698
The vacuum connectors are old OEM connectors I had from previous bikes. I just hacked them up to suite my need. Those hoses in my original post didn’t work out very well. I used heat shrink tubing to connect them and they started coming undone, so I switched to just a piece of fuel line between them. It worked much better. But I’ve completely changed it again. I just didn’t like the idea of any attached parts being in the filtered air area. Plus I didn’t like all that intake noise. I’ve gone with the Arlen Ness Big Sucker air cleaner that allows the use the of factory cover so it’s quieter but still is a high flow. I like the look of the stock factory cover better than all that exposed filter area.
crazytown (04-10-2023)
#699
old skool1983
10-07-2009 10:49 PM
jskwarek
08-15-2007 10:01 AM
