2014 enforcer wheels on a 2012 street glide
Old 01-12-2015, 06:53 PM
senna's Avatar
senna
senna is offline
Although as everyone has stated already that most people change the ABS bearing to a Non-ABS bearing or vise-versa, depending on how their bike is equipped, it is not an absolute necessity in all cases and can offer a cost savings to not do so.
For example, if you find a nice low mile set of Enforcers with ABS bearings already installed and you know the bearings are in great shape, then there is no need to change to Non-ABS bearings to install on your 2013 Non-ABS bike.
You would simply have someone with machining capabilities reduce the length (width) of your FRONT-LEFT and RIGHT-REAR Spacers by .117-.118 (3mm). That's the difference in length (width) between a 15mm std bearing and 18mm ABS bearing. All is good. I've done this several times.
Then whenever (or maybe never depending on how many miles you put on), you want/need to replace tires/bearings, install the Non-Abs bearings with 2 new original length spacers. Those spacers are inexpensive, $10.57 and $7.92 List price currently.
If find yourself in this situation and need the reduced length (width) spacers, I can help you with that. PM me if interested.
^^^^ This
Old 01-12-2015, 07:16 PM
TeamMudd's Avatar
TeamMudd
TeamMudd is offline
this is absolutely correct!! My low cost Enforcers were off an ABS bike. The shop had them swapped out at had a couple of spacers already set up. On the rear i had to change out the bearing spacer, and that was it, bolted right up.
this was contrary to the local harley dealer who said i would need 1) new spacers 2) new bearings and 3) caliper spacers plus labor bwaahahahahaha! I literally laughed when he listed off all the parts that i would "have to" have and then wondered how many people they scammed with that list.... what a shame.
Old 01-12-2015, 07:40 PM
TAKITO SEXY's Avatar
TAKITO SEXY
TAKITO SEXY is offline
That Ultra fender goes VERY well with an enforcer wheel. Keep them coming, this is definitely the first time l read about the bearing spacers being machined or shaved down to make it fit. I just assumed the bearing diameter was different size between ABS vs. non-ABS hence the need to swap.
Old 01-12-2015, 07:41 PM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,239 Likes on 1,815 Posts
Originally Posted by Hard Ride
I want to go one step further with ABS bearings. Can I use a 15 Enforcer wheel with ABS bearings on a 15 none ABS Ultra without changing the bearings.I think the axels are the same.
The specific year in the statement was directed to TAKITO SEXY because that's what he has, but I've now edited for you.
For example, if you find a nice low mile set of Enforcers with ABS bearings already installed and you know the bearings are in great shape, then there is no need to change to Non-ABS bearings to install on your 2013 (or any 2008 (Front Only) and 2009-2015 Touring (Front and Rear)) Non-ABS bike.
Old 07-30-2015, 07:29 PM
Hate Work's Avatar
Hate Work
Hate Work is offline
Default Bearing clarification
Time to open this thread back up. Is the only difference between an ABS and non-ABS bearing the length?
Also, for those that purchased chrome or polished rotors..... They look great. How do they last?
And one more thing.... Since I have a SG, is all I need for the rear is the wheel?
Thanks in advance.
Old 07-31-2015, 10:35 AM
multihdrdr's Avatar
multihdrdr
Dimensionally, length is the difference. Of course, there are differences cosmetically and internally.
I'm not sure what you're asking?
Old 07-31-2015, 02:26 PM
skratch's Avatar
skratch
skratch is offline
Received 4,220 Likes on 2,467 Posts
Old 07-31-2015, 07:19 PM
Hate Work's Avatar
Hate Work
I am under the impression that the rear wheel is plug and play, as my bike and the newer enforcer rear wheel are both 16". I'll just have the dealer work it out. Ordered the front wheel, polished rotors and bolt kit today. Just need time to drop off scoot.
Old 07-31-2015, 07:38 PM
multihdrdr's Avatar
multihdrdr
Yes, the 09-2015 Touring Rear wheels are interchangeable. You can re-use your existing IDS "cush-drive" pulley and brake rotor
Old 08-02-2015, 06:36 AM
Hate Work's Avatar
Hate Work
Default Rear wheel
Regarding the pulley and rotor for the rear.... In having a SG, I can only see a small amount of the wheel and hardly any of the pulley or rotor...
Is is a waste of money to purchase/install the chrome pulley and rotor on the rear? I'm thinking so....
Quick Reply: 2014 enforcer wheels on a 2012 street glide
