My toe shifter is flopping like a fish
So my toe shifter has been flopping around since i installed the extended lever. It rattled when I'm idling. I didn't notice it too much before but it's more pronounced now with the longer lever and longer/heavier shifter peg. I was at a dealer talking to a tech the other day and he said the shifter bushing needs to be replaced. Does this sound accurate, and if so, how difficult is it to replace?
I want to try to fix this myself.
Pretty easy,just drive the old one out with a punch or use a vice, same with the new. I would not grease the shaft, that collects sand makes it wear faster, I use silicone spray every five k or when I think about it.
Check and make sure the lever is tight on the shaft first. I had a couple seasons it kept coming loose on the shaft, ended up the splines inside the lever wore down, and messed up the shaft a little where it seats down on. Replaced shaft with a SS grease-able one, (forget who from) and replaced the lever
